there should be a midpoint mate option
anna_goldfarb
Member Posts: 2 ✭
so frequently I'll be working in an assembly and need to have something centered, and rather than needing to go into sketches and measure things and calculate location, it would be much easier if there were a midpoint mate. Just my 2 cents.
Did you explore all the power of width mate? Might not work, but make sure you check it out. .
The width mate sure has its flaws, as has the between mate connector. I second the necessity of a starightforward midpoint mate.
