FS Node Studio beta.
Konst_Sh
Member Posts: 124 PRO
Today within the set of other free Onshape automation tools by CadSharp we releasing in Onshape Appstore the beta version of unique tool for visual and interactive creation of Onshape's Custom features code - FS Node Studio.
It aims to abstracts away the most cryptic parts of Featurescript functions - the id's manipulation, and represents each function instance - the building block of your custom feature - as a diagram node with inputs, outputs and the links connecting outputs/results of functions with inputs of other descendant functions.
It has a special grouping constructs to represent well known code statements like if-else, try-catch, for loop, and embedable raw code fragment. It enforces type safety of passed values by checking type matching of source values and consumer argument type, so type annotations are your friends not just at runtime 😏 (but not be afraid, the unchecable Any parameter type will let you bypass type checks as we used to) . The tool has full publicly documented Onshape standard library set of functions and types.
The tool is capable to generate full FeatureStudio declaration code including custom types, enums, top level functions and custom features, except the import statements and FeatureScript version directive.
Also the current limitation is that you will not be able to save you diagram within Onshape tab and you will need to manually copy code from featurescript output of the app to FeatureStudio tab.
Introductory video by @MichaelPascoe
"you will not be able to save you diagram within Onshape tab"
This is confusing, since the demo video seems to show step by step editing of the node graph where it persists. What exactly do you mean?
Wow! That looks like an awful lot of work, and an amazing tool. Thank you for sharing.
I had a lot of fun testing it out and the idea of visual scripting is very appealing.
Probably especially appealing for non-developers I imagine.
This is actually what I thought FeatureScript was way back in the day when I read "you don't need to know how to code in order to do FeatureScript".
Way to go @Konst_Sh! This is super cool. 😎
@S1mon You can open FS Node Studio (BETA) from the app menu (Bottom left +) then when finished copy your code over to a Feature Studio. However, currently it is not saving the data anywhere. So if you close your browser tab and open it again, your data will not be saved unless you have copied it over to a Feature Studio.
Here is the forum post for the toolbox app:
CADSharp Toolbox App
FYI: We will post other individual pages for the other sub apps. This way you can follow along as they are updated like with Konstantin's FS Node Studio (BETA)
I mean the tab within onshape document, the own app tabs will persist while the user session is retained, but if you close it or refresh - it will not be saved.
Is this something that needs changes from Onshape to allow the tab to be persistent between sessions? Or would there be a way to add comments or other stuff to the generated code to allow it to become the storage medium?
nope, thats the matter of maturity of my data model. While it is still subjected to changes I don't want to handle possible conflicts of stored json and relevant data model. Another consideration is that i would like to check user interest before making farther efforts of integration it into OS.
Recently added support for interactive committing of code changes to the satellite feature studio, which is created and binded once app element is initialized. Now the generated code updates as user editing the diagram.
Amazing!
@S1mon thanks, I know you interested in being able to save the diagram state, but I'm not there yet. It will just remember the satellite feature studio for now.
FS Node studio got the update which improves the instance ordering capabilities in cases when the inputs/outputs are ambiguous, which occurs when you deal with effectful function nodes like print, sketch and instantiator.
Soon to be deployed feature of Node studio - auto-mapping of array outputs. If the output of the node has an array term the special array item out term will be created as well. The consumers of that term will be submerged into for loop, iterating through the items of the source array. This abstracts away one of the annoying parts of the workflows when user has to loop through the collections of items.
Few special rules regarding this feature:
map source term → normal target term ⇒ target instance get captured by for loop
map source term → instance inside loop ⇒ array item get accessed using existing loop iterator
source term of mapped instance → instance of array input term in the outer scope of the loop ⇒ special output from inside the loop will be generated
source term of id type of mapped instance → consumer instance in the outer scope of the loop ⇒ special id output will be generated using ANY_ID template
Diagram persistance has been recently added, now diagram data is saved to Onshape app element. This allows document level history tree version control just as native onshape's app elements. It will stay a test functionality for a while, so if data model of the app would undergo to any significant changes or app server will be moved to another location, I'm not guarantying that the diagram data will be preserved or will remain readable, though the generated feature studio code will not be affected whatever.
The demo video show the app element page reload and feature studio diagrams restoration process short after app is loaded (sorry for the quality, I assume its because of how non-standard frame size is converted by editors)
With some valuable feedback from @EvanReese I found that the use of delete button on Mac was not deleting diagram nodes and links, which works on windows. This is fixed now mac's delete/backspace works as expected.
Nice! thanks I'll try that out soon
Was pushed update which improves json payload size sent to onshape on model change, also added detailed decomposition for DistanceResult data type, which is frequently used and should improve evDistance node usage experience.
Improving json payload was a breaking change, so existing node studios will fail to deserialize and will default to empty state.
Also there was added an editable header section to feature studio code tab, where you can override featurescript version, imports and any user comments within // or /**/ markup
