Super Derive with scale option
I was inserting a logo to be subtracted from another part studio for machining using the standard derive feature and then boolean when it suddenly dawned on me that I had added super derive once upon a time never had a need or remembered I had it till now and wondered if it could do a few things like booleans and scaling. Wha.da.ya.know…. Booleans are in there. Sadly scaling was not. Anyway. it'd be a cool addition for logo's and I'm sure other uses to add a transform scaling option if possible. It would have to be able to do non uniform scaling for my particular example. Not sure who might be interested in added that or who owns the feature. But thank you.. very cool. If there's another option for my use case, let me know for future use.
I usually add a config variable in my logos that does the scaling, this way I can just pick the "size" directly when I derive it in.
I thought about that. But in this case the size was random and had to fill the space as much as aesthetically possible.
In that case you could create a measured variable for the width, and use that to drive the config
Huh. I wonder why I never thought of that. I use a measured width and then scale it with a desired width value in the target part studio, but using a config variable is brilliant!
Ramon Yip | glassboard.com
Yeah part studios with config variables is an overpowered workflow for slapping procedural geometry into new documents. One of my coworkers has an entire systemized hatch generator he made that uses Amalgamate to cut out 90% of the workload of drawing access doors on our cabinet exhibits where all you gotta do is specify the length and width of the hatch and it auto adjusts the number of latches and everything for you.
Derek Van Allen | Engineering Consultant | MeddlerAh good suggestion Evan. thanks. But not quite as elegant as doing the scale real time. Tried it out but I gotta hit the scale just right when grabbing that particular config. for the derive feature vs just tweaking it along with the locations and seeing how it looks with each adjustment. I will keep it in a config variable though as that is definitely better than the alternative.
Edit: I just reread that. measured variable. Hasn't quite sunk in what your suggesting there. Are you saying I can create a measured variable in the model. and then use that variable in a scale factor? Or would that only work for say setting a measured length variable and using that in the configuration selection? I might need to experiment more to understand that suggestion.
