Set Category with Featurescript?
EvanReeseEvanReese Member, Mentor Posts: 2,804 PRO
I'm trying to change a part category via FS. Some properties (like "Not Revision Managed") don't autocomplete, but can be set anyway as a "CUSTOM" property with the property ID. I hoped to do the same thing for a Category. Here's what I'm trying, but it isn't working. Has anyone else proven whether or not this is possible?
        const categoryID = "57f3fb8efa3416c06701d625";
        const categorySelectionID = "6983854abad5b851116b0a88";
        setProperty(context, {
                "entities" : entities,
                "propertyType" : PropertyType.CUSTOM,
                "customPropertyId" : categoryID,
                "value" : categorySelectionID
  • Caden_ArmstrongCaden_Armstrong Member Posts: 386 PRO
    Formatting the value is very counterintuitive, you need to put the property inside of a literal array - quotes and all:
    (And the forum is being weird with formatting so you get a screenshot)
    This is the value that goes into set property.
    If you do multiple categories, you add a comma between each and surround them with quotes.
