Compression thread with nut
dru_schwartz
Member Posts: 4 ✭
in Drawings
I am trying to make a compression locking nut. I want to place a pipe in a threaded cylinder and then use a nut to tighten down around the pipe.
I can get the nut to screw onto the thread,
but it doesn't tighten down on the pipe.
Can someone help with the design?
Please see the pictures attached for a better explanation.
Don't you need a pair of tapers to squeeze the slit sections against the outer pipe wall?
I'd imagine that simply scaling down the green nut by a small percentage would get you what you need. But that would also change the dimensions of the thread. So maybe reducing its hole size before the thread is created.
CADNurd's Linktree - find me everywhere else - https://linktr.ee/Liam.G
I figured it out
