Set Category with Featurescript?
EvanReese
Member, Mentor Posts: 2,807 PRO
I'm trying to change a part category via FS. Some properties (like "Not Revision Managed") don't autocomplete, but can be set anyway as a "CUSTOM" property with the property ID. I hoped to do the same thing for a Category. Here's what I'm trying, but it isn't working. Has anyone else proven whether or not this is possible?
const categoryID = "57f3fb8efa3416c06701d625";
const categorySelectionID = "6983854abad5b851116b0a88";
setProperty(context, {
"entities" : entities,
"propertyType" : PropertyType.CUSTOM,
"customPropertyId" : categoryID,
"value" : categorySelectionID
Caden_Armstrong
Member Posts: 389 PRO
Formatting the value is very counterintuitive, you need to put the property inside of a literal array - quotes and all:
(And the forum is being weird with formatting so you get a screenshot)
This is the value that goes into set property.
If you do multiple categories, you add a comma between each and surround them with quotes.www.smartbenchsoftware.com --- Renaissance --- fs.place
Experts in Onshape Automation - Custom Features and Integrated Applications3
Everyone needs to hire this man 👆
