oh its public now
You got a query variable set to evaluate on use with all solid bodies. The bodies being inserted are pretty solid after insertion. That means they get added to the subtraction scope. Was scratching my head real hard for that one.
Derek Van Allen | Engineering Consultant | MeddlerV16 - New updates: global rotation of all seeds to make flipping stuff easier. Composite part support for insertion operations.
Derek Van Allen | Engineering Consultant | MeddlerOmg that's it! insane. It was an excellent case study in why it's important to capture ALL of the right logic with your Query Variables, not just what happens to get the selection you want right now. I was actually able to fix it by declaring another qv of the same name with "evaluate on use" UNchecked. That's an interesting workflow I'd not considered. You can essential turn "evaluate on use" off/on at various points in your tree that way.
@EvanReese there's probably some utility there as well by starting with a QV evaluated one way on startup and then running a new QV with the same name copied into itself stored as Selection as some kind of cache, or to recursively iterate on queries. Or a qNothing.
