Why do some parts not show up in my drawings?
noah_hofer
Member Posts: 8 ✭
in Drawings
I am making an Arc Reactor, or have made one: my own adaption of the one iron man has. Anyway I wanted to make a blueprint of it, and i made a section view, and some of the main inner tubes don't show up. Why is this?
P.S. Its public have a look.
Options_Ðave_ Member, Developers Posts: 712 ✭✭✭✭I can't determine if the drawing was made from the part studio or the assembly but if you wish to see multiple parts in the drawing I believe the drawing must be creates from the assembly.
5 -
Options_Ðave_ Member, Developers Posts: 712 ✭✭✭✭I tried to make a drawing from your assembly and discovered that the inner rings do not exists in the assembly tab. Please insert these parts into your assembly and create a drawing from the assembly. It should work.
5 -
Tagging @bobminer
