Global Setting of Document Units
Is it or can it be made possible to set the units for all users in the company to align. Our current workaround is to have a document template which can be copied for new documents, and for imports we set the workspace units before import. However this is not a great solution, and would love it if there was a function, maybe in the enterprise settings, to set the units for all user and all documents.
  • judith_davisjudith_davis Member Posts: 1
    edited February 7
    @ geometry dash: No, Onshape currently does not provide a company-wide or enterprise setting to enforce units for all users and all documents.
  • Richard_TibbottRichard_Tibbott Member Posts: 5
    Thanks for this response, Can I request this be put on the list for future developments, it seems like a big miss and something which is common for other CAD packages. We currently are using a template document as a work around, however this is a bit cumbersome and it seems like this could be included in the enterprise settings much the same as the BOM table setup.
