Remove Hach
ingenierie_polymosingenierie_polymos Member Posts: 1 PRO
Is there a way to remove the hatching from the simulation of a solid part?
  • chris_gromek_onshapechris_gromek_onshape Member, Onshape Employees Posts: 29 image
    Greetings,
    Cross-section views of Simulation results are not currently available. We recognize the value in this capability, but in order to implement it requires rework of our results pipeline (i.e. making results queryable post-solve) which will take time. For now, Simulation results are available only on the surface of Parts. The hatching is an effect of the cross-section view and does not obstruct from Simulation results beneath the surface.
    Thank you for your question, I am sorry that we do not have a solution at this time.
    Best Regards,
    Chris
