3D from Excel to Onshape
jacek_zagaja
Member Posts: 47 ✭✭
Below is Excel file with macro:
https://sphericalhorns.net/wp-content/uploads/2021/03/DrBA_JMLC_V303.zip
that computes cross section point cloud with parameters on Sheet1:
Points are on Sheet2 but hard to see gap between step size.
- Min. points per ellipse
- Ellipse step size [mm] - step in Z direction
https://cad.onshape.com/documents/e161fbe2d3ea5f28da279c93/v/be9e27c457dc6f53de95e809/e/8d2acc927cc9433b70245871
https://cad.onshape.com/documents/ae2be4f95e789a8efda1315d/w/3cf31603c523c20e4099c20d/e/8f6f9236b006f146876f5554
The loft is still done manually (and I only used two of your shared tables). But here's a link to another article with a similar challenge including a FeatureScript that creates a loft based on your coordinate data.
https://forum.onshape.com/discussion/19542/spline-plus-cross-sections-for-loft#latest
If still interested, I can give you a hand to do it. It will not be too difficult to automate.
Hey,
Ran into something similar while trying to import point-cloud data from an Excel macro into Onshape. Turns out the issue wasn’t FeatureScript it was how the sheet was exporting the CSV (regional delimiter settings messed up the formatting).
Switching to a different spreadsheet environment with better control over CSV encoding/separators actually fixed the import errors for me especially when dealing with multiple cross-sections in one file.
If you're stuck with inconsistent CSV exports breaking your loft workflow, this helped in my case:
https://www.wps.com
Also worked offline, which was a plus for local automation setups.
