Can't knurl or chamfer a surface
jason_angus572
Member Posts: 8 ✭
in Drawings
Hello, Noob here. I am trying to create my first project after doing some training and test projects. I was able to easily knurl surfaces and chamfer edges, but now I have a surface on a cylinder that will not let me do either. Please help.
It's always easier to help with a link to public document! :)
Ok let me figure that out. I will add it here when Im done. Thank you
https://cad.onshape.com/documents/e5f14c796aa9b0f82f91ea66/w/45668ef1d20142899052f30b/e/a9449cd6d90e9d93f39c7409?renderMode=0&uiState=699a03c899e30ef577863c36
I went back and recreated the project and added the chamfer and knurl earlier in the project. Now I am having problems extruding a 1.25 wide by .05 area on the bottom. When I go to do the extrusion and hit remove, it turns red.
You will need to make the document public via the share button for anyone to view or copy.
