Schedule Assignments feature request
Corey
Member Posts: 12 EDU
Currently, when creating assignment's it is left in a Draft state untill [Publish assignment] is selected. I believe it would be useful to be able to schedule the assignment with a Date and Time picker. The Picker should include NOW, or Date and time
With that, a Close assignment scheduler would also be helpful. Like the Publish scheduler, it should include NOW (If Active) or Date and Time, For a bounse, maybe a timer option to set for HH:MM after published.
Not sure if you saw but this was just added in last week on the 20th update. Helps a ton.
-Joe
