Can I add arrow notes or callouts to an inserted image?
joshtargojoshtargo Member Posts: 494 EDU
I want to add arrow notes or callouts to an inserted image, kind of like a brochure, for a presentation. I can't seem to do anything that has an arrow or even a line without a standard view of a part. Is this possible?
  • Kevin_CowlesKevin_Cowles Member, Onshape Employees Posts: 59 PRO
    So inserted images don't retain transparent background it seems. So can't insert an image of the arrow. You can draw one with the drawing sketch tools and modify line color and weight (see right arrow). Or model an arrow in a part studio (better yet configure it! For any size/aspect ration, can also scale that view).
    Both the inserted model view of the arrow, and the drawing sketch, will show on top of the inserted png (the black arrow here is an image) if you send the image to back
  • joshtargojoshtargo Member Posts: 494 EDU
    I guess it works to a degree, but it is far from what I need.
