Tolerances in 3D
Yann_Roth_91
Member Posts: 7 ✭✭
I am thinking of a feature that I don't think exist in any CAD software : full integration of tolerances at 3D level. Currently, tolerances are only added in the drawing and only as a display note (no actual implication on parts). Having all the tolerances defined during 3D modeling would considerably ease the process to create drawings. And the main feature I would want to emerge from this change of paradigm is to be able to actually visualize extreme cases considering entered tolerances. This would be a huge help in collision detection for precision parts.
6
I think there's a lot of interest in it, but I think it'll take a lot of time for people to move away from their reliance on paper drawings. There is an improvement request here: https://forum.onshape.com/discussion/comment/51049#Comment_51049
Inventor has tolerance analysis:
https://knowledge.autodesk.com/support/inventor-tolerance-analysis/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/INVTOL/files/GUID-38E025E4-D5C1-46CC-B5CC-67F52CB39139-htm.html
Solidworks has TolAnalyst and DimXpert:
https://help.solidworks.com/2022/english/SolidWorks/sldworks/c_tolerancing_overview.htm?id=f534e416795940bab793412d3bc162ec#Pg0
Honestly it's one of Onshape's greatest deficiencies, especially considering how easy it would be on the user with all the dependencies you could screw up in file-based systems.
https://forum.onshape.com/discussion/18212/model-based-definition-and-tolerance-analysis#latest
I’ve been exploring similar challenges and found that https://www.excedify.com/ really helps in understanding how tolerances affect part assembly and function. Even though full 3D tolerance integration isn’t there yet, using it alongside CAD models has made visualizing extreme cases and fit much easier in my projects
