can onshape import a stl (mesh) file as a solid to make moderations?
leroy_marshallleroy_marshall Member Posts: 2
  • S1monS1mon Member Posts: 4,056 PRO
    Not sure what you mean by "moderations", but if the STL is water tight, you can treat it somewhat like a solid and do other regular operations on it.
