Unistrut Frame Profile(s)
brandon_nichols678brandon_nichols678 Member Posts: 15 ✭✭
So I build a lot of stuff outta Unistrut™ a.k.a. channel strut, and I recall seeing an OnShape Frame feature tutorial using what I thought were channel strut profiles.
But alas I can find no channel strut in the standard libraries (the 8020 looks great!), and a search of the forums came up empty as well.
Always striving to not reinvent the wheel, any suggestions?
Thanks in advance!
Brandon W. Nichols, PE
Seattle, Washington
  • glen_dewsburyglen_dewsbury Member Posts: 1,297 PRO
    You can make your own Unistrut profiles for the frame tool. It won't produce slotted versions of course. That would need to be added after.
    Draw sketch in it's own part studio ( can be configured) then look for the TAG tool to set them up. Probably wants it's own document making it easier to control and use in subsequent documents.
    https://cad.onshape.com/documents/5e2bf792ada5f90b46d34836/w/fd683928a9281a219958e6ad/e/ed854352884d8d70207bfd9a
    https://www.northstarindustries.ca/collections/unistrut/products/unistrut-p1000-20-pl-1-5-8-x-1-5-8-channel
  • brandon_nichols678brandon_nichols678 Member Posts: 15 ✭✭
    edited March 8
    @glen_dewsbury thanks for the leg-up, your example doc was very helpful!
    Ran with it to sketch both full depth and low profile channel profiles, and a configurable STRUT FRAME document with add-on slots
    While this composite part layout sketch allows frames to be defined 'on demand' in any size with either profile, it is specifically designed to hit the centerline between slots if the #LN is held to even integers, and the #WD held to odd integers, allowing 1/8 of an inch clearance on each end of the contained parts, representing saw blade cut loss.
    Result is an actual #LN equal to the nominal, and actual #WD that is 1/2 inch larger than nominal. the extra half inch resulting from two 1.625 width channel struts plus two 1/8 inch saw cut allowances, equaling 3.5 inches instead of value 3 used in config nominals. Most projects using channel strut have a tolerance on the order of ± 1/8 of an inch, so the saw cut losses are really immaterial
    Fundamentally holding cut lengths to even integers wherever possible when designing with strut channel minimizes sawcut labor and material waste.
    Bottom line, in STRUT FRAME the cut length of the uncontained members equals nominal #LN, and the cut length of the contained members is 3 inches less than nominal #WD..
    Having some trouble populating 'Description' field in the composite part cut list, and determining if 'branched versioning' is the right way to handle 'on demand assembly configurations', but these are subjects of future discussions.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,597 PRO
    I had a look at this coming from the other thread…
    An alternate to using the frame tool is to just create a strut channel part with configurable length via a config variable and insert this in your assembly to create an assembly you can configure "on the fly" using config variable. I haven't setup the slots to adjust their location depending on the length as it takes a bit of math to setup but you could definitely do that…
    You can also do the "low profile" channel as a configuration of your profile sketch, there is no need to duplicate it (for this or for the frame).
    Also note that your mating scheme is… let's just say "suboptimal"! Using a circular pattern cuts the work in half but even without that you only need one mate per corner bkt:
    https://cad.onshape.com/documents/51afdb6e53ee0b8ae409b61e/w/eeb8bfcda23536a115fffb13/e/ed1f46323536a4e49b4dc17c?configuration=Height%3D0.45720000000000005%2Bmeter%3BLow_Profile_%3Dtrue%3BWidth%3D0.5334000000000001%2Bmeter&renderMode=0&tangentEdgeStyle=1&rightPanel=configPanel&uiState=69ae309fd71bcbb5cee62ea6
    Also you might want to have a look at how to do the auto naming of the strut as this would be applicable to the composite frame (if you prefer to use that option):
    edited 3:08AM
    Thanks for your expert feedback, @eric_pesty very helpful!
    Yep I agree, one fastener mate beats 3 planar, the problem is consistent reference point locations for mate connectors — sometimes it's a hole, sometimes the centerline of a channel, sometimes RH sometimes LH, sometimes I just find it easier to untangle the rats nest one axis at a time.
    As for the mirroring and patterning, yes I'm aware of those features but they seem to break the flexibility of the design intent, which allows for replacement of any fitting sub- assembly within any FRAME configuration, and any fastener sub-assembly within any fitting. which is how stuff often gets built IRL — not always with uniform fastener packages or same fittings at every corner, e.g. attached screenshot.
    Had some trouble earlier, but OnShape now seems to be all rolling up identical components from different sub-assemblies as expected in the BOM.
    Believe me I'm just getting started, OnShape is really cool, probably 60 hours into it with 0 downtime for software update or system crash, and that's HUGE for me given the time I wasted over the past 3-4 years fighting those issues.
    Again thanks, for your help, have another question with respect to versioning that deserves its own post, incoming!
    Seattle, Washington
    Fair enough about the mix-and matching of the hardware!
    The thing about having multiple mates is that you can end up with conflicts that are a real pain to troubleshoot whereas a single won't give you these troubles and is generally a lot easier to fix. It's a bit of an adjustment compared to other CAD systems but once you get the hang of editing mate connectors on the fly (re-align, rotate, offset), it's really nice not to need multiple mates so I would recommend trying to stick to a single fastened whenever possible.
    The corner of the bkt to the virtual sharp of the channel I used are super simple but there might some tricker case for which it might be worth setting up a couple explicit mate connectors in the hardware and/or strut parts to make it easier to handle various layouts.
    Just noticed your auto part-naming suggestion, yep I'd like to learn how to do that, perhaps get an intro into the advanced user API?
    Lots to learn!
