Export Issues
wayne_sauderwayne_sauder Member, csevp Posts: 649 PRO
Has anyone else had trouble with this showing up when exporting? DXF will export fine, but I have been getting this message a lot with most 3D file types.
  • Vajrang_ParvateVajrang_Parvate Member, Onshape Employees Posts: 17 image
    Hi Wayne,
    I had a quick look in our logs - this doesn't seem to be a widespread issue with other users / docs.
    There is something specific in your doc/workflow that is causing multiple thousands of downloads of exported files. Do you have a particularly complicated assembly or something that you're trying to export?
    In any case, could you please open up a support ticket and share your doc + workflow with the support team so the we can take a deeper look?
    Thanks,
    Vajrang.
    SVP, Onshape Product and R&D
  • wayne_sauderwayne_sauder Member, csevp Posts: 649 PRO
    @Vajrang_Parvate
    Thanks. Support has had a ticket for a couple of days now. Just posted here to see if anyone else was having similar issues.
