Rejected Workflow - No Clone Option
stuart_aspinallstuart_aspinall Member Posts: 17 PRO
edited March 13 in General
So I did a workflow, and it was rejected by peers, so I looked in the help and it tells me to select the version tree for the Release, right click and go to the Release Workflow, which it does, then Clone the Release Workflow, which will then keep all the parts in the workflow, and then can edit the required drg/model to correct the error…. ….but there's no Clone option. Anyone know a reason why there's no clone option. Using Enterprise and Im a full user.
Stu
  • Kevin_CowlesKevin_Cowles Member, Onshape Employees Posts: 62 PRO
    It may due to where you are in the Versions and history when you attempt to clone it. Try going to the Main, then right click the rejected release, and then attempt to clone? And ensure you still have access to all of the items in the release.
    If you still don't see the clone option from there, then I would log a support ticket. That will be much easier to debug that sharing screen shots or a link share.
    Also, you'll want to make the changes to the model before resubmitting the release, so you could either make changes then clone → submit, or clone → save draft before making the changes.
