Hollow
chandrashekar_r
Member Posts: 51 ✭
in General
Hi
I need to make the rectangle box hollow inside. If I do shell it gives error
https://cad.onshape.com/documents/7c375b83de337f3bc0c2a432/w/3967dd22dc6dcc7356c9b7a5/e/b40e9ba491fc34375c1905c2?renderMode=0&uiState=69b6a1909de2ad797287109e
By moving the shell behind the extrude that made it shell will work. If not it's trying to shell the ring standing of from that ring. It can be done if the shell thickness is reduced enough, but I don't think that's what your after.
https://cad.onshape.com/documents/04fe019f99cd0ccb6b775b7b/w/bee17d4e6c66aa8adb81dd5a/e/ae459338791c49e0191c4cf5
Insert the Shell feature before the thin sections.
