How to define a range dependent variable?
adi_noyboer004adi_noyboer004 Member Posts: 2 PRO
Hello to you all,
I'm trying to define a variable (z) by a range of values for variable (k)
'k' range 'z' value
6<z=<8 1
8<z=<10 2
10<z 3
I was trying to define a variable by nesting expression { ((#k>6&&#k=<8)?1:(#k>8&&#k=<10)?2:3) }, but to no avail.
Please advise.
Sincerly
  • _anton_anton Member, Onshape Employees Posts: 534 image
    <=, not =<
  • adi_noyboer004adi_noyboer004 Member Posts: 2 PRO
    I tried it as well, same resaults
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,640 PRO
    It gets a bit confused about the second part of the ternary, this should work if you add these brackets:
    (#k>6&&#k<=8)?1:((#k>8&&#k<=10)?2:3)
  • S1monS1mon Member Posts: 4,092 PRO
    @EvanReese has a series of 6 videos on expressions and logic in Onshape. I highly recommend watching these since there are a number of useful tricks or things you might not have picked up from other sources.
    https://www.youtube.com/watch?v=J7McsBIEeqc
