Help with featurescript subtraction
calvin_selin
calvin_selin Member Posts: 11 EDU
link: https://cad.onshape.com/documents/a8c134757a29b9f4453f6e31/w/6b12b36328a688485352be68/e/984235c5f06469cc73216905
I think my code's probably super messy, so sorry.
So, I'm trying to make a featurescript that will make holes in the end of square tubes. I got it to make a sketch with a circle, and Extrude it through all, but when I run the subtraction, it doesn't work. Do ya'll know why?
this is my intended result, if it helps.
If you can help, thank you!
  • Jed_Yeiser
    Jed_Yeiser Member Posts: 62 PRO
    edited March 25
    I suspect that your issue is the queries that you're passing ito the boolean:
    "tools" : qCreatedBy(id + "extrude" + i), → All entities created by (id + "extrude" + i). Bodies, Faces, Verticies, Edges, etc. Note that I'd recommend changing this code to qCreatedBy(id + ("extrude" ~ i)). Id's can get brittle, and I've found that concatenated pattern to work well.
    "targets" : evaluateQuery(context, qOwnerBody(qUnion(faces))), —> This seems like a backwards way to get what you're looking for. Why not just pass the part in as a parameter?
    As a quick fix/test, I'd do the following:
    1. Filter your tools down so it's just getting bodies. You can do this by adding an EntityType.BODY and or BodyType.Solid to your query, or by wrapping an additional Entity/Body type filter around your tools query.
    2. Add debug entities for both your tools and targets. Are they showing up as you'd expect?
  • calvin_selin
    I did the first thing, but it didn't fix it.
    What do you mean by a debug entity?
  • Jed_Yeiser
    I'd look into the featurescript classes at learn.onshape.com. I'd also look at how you're getting entities with qCreatedBy - when you type it out, tooltips pop up and could help you get the query you're actually looking for. addDebugEntities is a way of highlighting certain entities which is really helpful when debugging a feature (and occasionally, to make feature operation more intuitive to the user).
  • calvin_selin
    Fixed it.
    Here's what I put for the Boolean
    opBoolean(context, id + "boolean1", {
    "tools" : qCreatedBy(id + ("extrude" ~ i), EntityType.BODY),
    "targets" : qOwnerBody(face),
    "operationType" : BooleanOperationType.SUBTRACTION
  • calvin_selin
    Alright! I'm back for more!
    I basically completely redid it, and my code is much cleaner and more optimized, but it's giving me an error and in the featurescript panel its says "@opExtrude: CANNOT_RESOLVE_ENTITIES".
    I'm not sure what's up here. I think it has something to do with my sketch, maybe, but I'm not sure.
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,123 image
    annotation { "Feature Type Name" : "Tube Plug", "Feature Type Description" : "Makes Holes in a tube for a tube plug" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Tube Ends", "Filter" : EntityType.FACE } // Parameter "Tube Ends", filter for Faces
            definition.tubeEnds is Query;
            var i = 0;
            for (var face in evaluateQuery(context, definition.tubeEnds))
                const allEdges = qAdjacent(face, AdjacencyType.EDGE, EntityType.EDGE);
                const edges = [qLargest(allEdges), qLargest(qSubtraction(allEdges, qParallelEdges(allEdges, qLargest(allEdges))))];
                for (var edge in edges)
                    var holeFace = qSubtraction(qAdjacent(edge, AdjacencyType.EDGE, EntityType.FACE), face);
                    var sketchPlane = evPlane(context, { "face" : holeFace });
                    var sketchId = id + ("sketch" ~ i);
                    var sketch = newSketchOnPlane(context, sketchId, {
                            "sketchPlane" : sketchPlane
                    skCircle(sketch, "circle1", {
                                "center" : vector(0, 0) * inch,
                                "radius" : .105 * inch
                    skSolve(sketch);
                    opExtrude(context, id + ("extrude" ~ i), {
                                "entities" : qSketchRegion(sketchId),
                                "direction" : -sketchPlane.normal,
                                "endBound" : BoundingType.THROUGH_ALL
                    opBoolean(context, id + ("boolean" ~ i), {
                    i += 1;
    S1mon Member Posts: 4,615 PRO
    @NeilCooke
    I know this is a quick example and not particularly performance bound, but isn't it better to say:
    const endFaces = evaluateQuery(context, definition.tubeEnds;
    for (var face in endFaces)
    You do something similar with the inner loop.
  • NeilCooke
    @S1mon the evaluateQuery is only evaluated once to produce an array so it should make no difference.
    The biggest performance hit here is doing multiple opBoolean's - they should be all collected with some clever id grouping and done once at the end.
  • calvin_selin
    That worked! Many thanks!
  • calvin_selin
    Alright, I've now almost finished.
    I want it to put the holes in the end of the tube no matter the orientation. I can't manage to get it to always put the holes in the right spot though. It sometimes just doesn't make them and it sometimes makes half of them. I think it maybe has something to do with the way I oriented the planes. I have the z axis set to the normal of the plane and the x axis to the edge between the sketch plane and the tube end. Is there a better way to define this?
    Sorry for the bother.
