Help with featurescript subtraction
calvin_selin
Member Posts: 11 EDU
I think my code's probably super messy, so sorry.
So, I'm trying to make a featurescript that will make holes in the end of square tubes. I got it to make a sketch with a circle, and Extrude it through all, but when I run the subtraction, it doesn't work. Do ya'll know why?
this is my intended result, if it helps.
If you can help, thank you!
I suspect that your issue is the queries that you're passing ito the boolean:
"tools" : qCreatedBy(id + "extrude" + i), → All entities created by (id + "extrude" + i). Bodies, Faces, Verticies, Edges, etc. Note that I'd recommend changing this code to qCreatedBy(id + ("extrude" ~ i)). Id's can get brittle, and I've found that concatenated pattern to work well.
"targets" : evaluateQuery(context, qOwnerBody(qUnion(faces))), —> This seems like a backwards way to get what you're looking for. Why not just pass the part in as a parameter?
As a quick fix/test, I'd do the following:
I did the first thing, but it didn't fix it.
What do you mean by a debug entity?
I'd look into the featurescript classes at learn.onshape.com. I'd also look at how you're getting entities with qCreatedBy - when you type it out, tooltips pop up and could help you get the query you're actually looking for. addDebugEntities is a way of highlighting certain entities which is really helpful when debugging a feature (and occasionally, to make feature operation more intuitive to the user).
Fixed it.
Here's what I put for the Boolean
opBoolean(context, id + "boolean1", {
"tools" : qCreatedBy(id + ("extrude" ~ i), EntityType.BODY),
"targets" : qOwnerBody(face),
"operationType" : BooleanOperationType.SUBTRACTION
Alright! I'm back for more!
I basically completely redid it, and my code is much cleaner and more optimized, but it's giving me an error and in the featurescript panel its says "@opExtrude: CANNOT_RESOLVE_ENTITIES".
I'm not sure what's up here. I think it has something to do with my sketch, maybe, but I'm not sure.
annotation { "Feature Type Name" : "Tube Plug", "Feature Type Description" : "Makes Holes in a tube for a tube plug" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Tube Ends", "Filter" : EntityType.FACE } // Parameter "Tube Ends", filter for Faces definition.tubeEnds is Query; } { var i = 0; for (var face in evaluateQuery(context, definition.tubeEnds)) { const allEdges = qAdjacent(face, AdjacencyType.EDGE, EntityType.EDGE); const edges = [qLargest(allEdges), qLargest(qSubtraction(allEdges, qParallelEdges(allEdges, qLargest(allEdges))))]; for (var edge in edges) { var holeFace = qSubtraction(qAdjacent(edge, AdjacencyType.EDGE, EntityType.FACE), face); var sketchPlane = evPlane(context, { "face" : holeFace }); var sketchId = id + ("sketch" ~ i); var sketch = newSketchOnPlane(context, sketchId, { "sketchPlane" : sketchPlane }); skCircle(sketch, "circle1", { "center" : vector(0, 0) * inch, "radius" : .105 * inch }); skSolve(sketch); opExtrude(context, id + ("extrude" ~ i), { "entities" : qSketchRegion(sketchId), "direction" : -sketchPlane.normal, "endBound" : BoundingType.THROUGH_ALL }); opBoolean(context, id + ("boolean" ~ i), { "tools" : qCreatedBy(id + ("extrude" ~ i), EntityType.BODY), "targets" : qOwnerBody(face), "operationType" : BooleanOperationType.SUBTRACTION }); i += 1; } } });@NeilCooke
I know this is a quick example and not particularly performance bound, but isn't it better to say:
const endFaces = evaluateQuery(context, definition.tubeEnds; for (var face in endFaces) {…You do something similar with the inner loop.
@S1mon the evaluateQuery is only evaluated once to produce an array so it should make no difference.
The biggest performance hit here is doing multiple opBoolean's - they should be all collected with some clever id grouping and done once at the end.
That worked! Many thanks!
Alright, I've now almost finished.
I want it to put the holes in the end of the tube no matter the orientation. I can't manage to get it to always put the holes in the right spot though. It sometimes just doesn't make them and it sometimes makes half of them. I think it maybe has something to do with the way I oriented the planes. I have the z axis set to the normal of the plane and the x axis to the edge between the sketch plane and the tube end. Is there a better way to define this?
Sorry for the bother.
