Drill Press Hub
kent_ambergkent_amberg Member Posts: 2
I am trying to create a basic Milling Machine Hub for my pinion on my Enco because the handle holes are worn out, and i need a new one, and they are not available, can someone tell me how to create the holes on the angled plane on the sides, i managed to get one using the original sketch before revolving it, can i create other sketch views at 120 degrees from each other? Not sure what i am doing wrong?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 778 ✭✭✭
    Hello Kent. The only other feature you need to provide the additional holes is a Circular Pattern feature. In that feature's dialog select the feature you used to create the hole and the sketch centerline of the hub for the axis. - Scotty
