Sketches won't loft
brad_shostak
brad_shostak Member Posts: 4
I am trying to get the two faces in my document to loft be each time I try the inner profile just goes red. No idea how to fix this, would really appreciate some help.
https://cad.onshape.com/documents/a029e4e0f14f06e8c8efb638/w/5c0b632cb8f6c2a9d3d007c4/e/e7762b37295653af6d83ecfc
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 984 PRO
    I bet the error you're getting says "cannot use faces or regions with inner loops as profiles."
    S1mon Member Posts: 4,502 PRO
    You need to do the loft in two steps (outside and inside), or loft the outside and shell it.
  • Matt_Shields
    Or use thin :)
  • brad_shostak
    Thanks for the input but I still can't seem to get this to work. What am I missing??
  • Matt_Shields
    Try making it thinner? Or flipping the thickness direction?
    Easiest would be to share a link to your public document.
  • MDesign
    MDesign Member Posts: 1,461 PRO
    edited April 10
    With a circle you'll likely have to set connections in the loft feature or break up the circle in segments that the loft can connect to the other profile
