Is there a Featurescript for finding and replacing certain dimensions.
colin_king506colin_king506 Member Posts: 61 ✭✭
I have sketched several dozen and I need to do it without going through all individually. I thought I saw a video for onshape that used this 'script.
  • ruben_kwastruben_kwast Member Posts: 23
    If it's the same dimensions every time, you might want to switch them to variables. It only hurts once, and you'll remind yourself of it the next time you find yourself repeating dimensions a bunch.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,673 PRO
    I think this would normally be achieved by using variables, but this requires planning ahead…
    FS isn't going to be able to do this after the fact. It might be possible through the API but probably not worth the effort…
