Best way to pattern Honeycomb part
Connor_G_JonesConnor_G_Jones Member Posts: 4
Hello, I'm looking for the best way to make a Honeycomb wall. unfortunately my part has some "complex" geometry so I can't seem to get the fill pattern tool to work. I started by created a single cell and then orignally did multiple linear patterns to form the wall. I have tried this 2 difference ways one taking 8.91 seconds and another 3.91 seconds. This throws a flag in my brain and makes me think that there is probably a more simple efficient way that I don't know about.
https://cad.onshape.com/documents/9488c6ae37762abbc1ead355/w/10dc564e8253812856bd9c51/e/ae376145690db3e392b7930c?renderMode=0&uiState=69e7d383dbab1ef21e3f3bd6
If anyone has questions or has advice I'm all ears thank you!
  • jelte_steur_infojelte_steur_info Member Posts: 668 PRO
    have you looked into @EvanReese's grid extrude:
    https://cad.onshape.com/documents/d1489499c6bfdc52ce5cf32a/v/c8434e78be6e712bab86bd1d/e/1e65c10a40f2fe803e5816de
    and I've created a 'hexagonal' pattern tool for other cases:
    https://cad.onshape.com/documents/784dc878d42b19c14bb62f6e/v/1b822ebbc176a1ce6f121c36/e/f3c821d0e6a0efec9f85612e
  • Philip_Thomas_PTCPhilip_Thomas_PTC Member, Onshape Employees Posts: 19 image
    edited April 22
    Its hard to know exactly what you're looking for, but I hope this saves you some time.
    https://cad.onshape.com/documents/9cb887558d3b0fb2522b0f90/w/0b74d1d48e42571a0fca1c61/e/fa756a84975569dce74dc529
    Heres another one for you to play with
    https://cad.onshape.com/documents/9475efc7d2b70d180736de37/w/c64519094b6d87996e9823e6/e/c19a9aef97b2dc8bbc9c44e4
  • Connor_G_JonesConnor_G_Jones Member Posts: 4
    The 'hexagonal' pattern tool was the key. I had tried the grid extrude and fill pattern already however they didn't provide quite the functionality I was looking for.
    My current method was using linear patterns multiple times and resulted in long load times.
    Fill pattern would throw errors, I believe due to the geometry that I was trying to pattern. Grid Extrude didn't capture the geometry I needed. Images of errors and feature below.
    Fill Pattern Error
    Thank you guys for your assistance!
    Glad it's been of good use to more than just myself and my Featurescript coding learning
