New FeatureScript: Plastic Threads
william_knoblauch
Member Posts: 21 ✭✭
Hi everyone,
I've recently been messing around with FeatureScript and decided to make a thread feature for 3D-printed plastic parts. The general concept came from the ThreadCreator script written by David Cowden almost 8 years ago. His script works really well and has even more configurability than mine but I wanted to tap into a more specific market than his captures. This FeatureScript aims to create internal and external threads that can be printed and immediately threaded together with little to no post-processing.
You can find the FeatureScript here Plastic Thread. The document has many examples as well as the full code base. If you have any comments or concerns please leave them below.
Features:
- Automatic pitch definition for basic threads with optional user input
- Only one thread type: ANSI Standard (Could add more in the future if there is demand)
- Internal and External Threads
- Multi-start threads for ease of assembly
- Left/Right handed threads
- Configurable threaded length
- Mate point for easy mating of assemblies
- Precalculated thread tolerance for easy threading given no post-processing
Please don't use this to create threads for metal bolts or other metal parts you want to machine. I cannot ensure the threads work with CNC or metal 3D-printed parts.
To create threads, simply provide a cylindrical face representing the major diameter of an external thread or the minor diameter of an internal thread:
From there many options can be configured from the number of starts to the handedness of the thread, and the thread length. Create a mate point to easily add a mate connector to the center of the thread for use in an assembly.
If you have a bolt and a nut you can easily select both and create the same threads on each in one step.
The tolerance between both internal and external threads is handled right away by the script:
A function predetermines the tolerances and a tighter version of this function can be selected.
Some limitations associated with this FeatureScript are:
- Only one thread profile type. Even from Dave's Thread Creator script, there is no difference between the ANSI and ISO standard profiles (other than the naming convention).
- No tolerance input meaning you cannot change the backlash of the threads. Currently, a log function determines the tolerance and has 2 versions a default "loose" tolerance and an optional "tight" tolerance. The "loose" tolerance function is designed to work at any diameter and ensure the parts thread together even with a lower-quality print with a poor surface finish.
- Major/minor diameter input. I would like to add this in a future update
- No starting or ending chamfer inputs. Chamfers are predetermined by their location and the number of thread starts.
- Lead in input. (I don't find it useful enough for a 3D-printed part because it doesn't have to follow machining conventions. Also don't you just want your threads to end where you wanted them to)
- Intelligent feature naming. I couldn't figure out how to add a nice name to the feature when it was created so I didn't and instead, there is an option to show the pitch of the threads in a message.
- Thread clocking. I haven't added this yet. Let me know if it would be useful and I'll add it to my feature requests.
I have some additions in mind to make the script either more configurable or more robust.
Possible Future Additions:
- Major, and minor diameter inputs to control every dimension and aspect of the threads.
- Lead in functionality to make the threads prettier and maybe stronger.
- Partially threaded internal threads (I don't know what use this would have right now).
- Intelligent feature naming to make seeing the pitch easier.
- Thread clocking to move the start of the thread relative to the rest of the part.
I haven't actually had the need in a while, but one thing I could see is handling standard plastic bottle threads. They have a particular thread form and start/end which is a result of the keyway style cutters used to make the injection mold tools.
Here's a link to an older version of the standard.
Dope! Ty
RENDERCAD
I forgot to add the link to the post.
Plastic Threads
@S1mon,
It shouldn't be too hard to add the profile but the start/end will be fairly difficult to get parameterized. How do you normally model the start and end of those threads? Do you use a loft from the blunt end of the threads into the cylinder or is there another method you use?
@william_knoblauch
The ends are revolved to simulate the diameter of the cutter. I'm not sure what the typical cutter diameters are, but I think I may have stumbled on some spec drawings at some point with this info.
I like this!
Two issues which arise as I use it:
A feature request would be to be able to choose multiple holes in one operation. It clutters up the feature tree to have a thread operation for each and every hole which needs to be threaded. And because a print truly needs every threaded hole to be threaded in the CAD, the ThreadCreator approach of only threading symbolic holes doesn't translate well.
Hey @kenn_sebesta167,
Thanks for the comment and recommendations. I'm sorry I didn’t get back to you sooner. I haven’t looked at the forums in a little while.
I changed the layer thickness error to show up as a tooltip and to show the “correct” layer thickness. Of course, by “correct” layer thickness I mean the layer thickness ensuring that a single layer captures the flat section of the thread profile. This is an estimation of what would work and in my experience, it prevents tiny threads from printing with too little detail/resolution.
The error you are getting with the cone removing geometry from your part is an oversight on my part in testing. That is the chamfer cone cutting the chamfer on the threads at the exit of the hole. The chamfer cone should scale with the pitch of the threads to not interfere with the rest of the part but in that circumstance, it was not scaling correctly. I have fixed the error so you can thread the hole without it cutting into any other section of the part.
I also updated the script to allow for many hole and stud selections. The main reason for holding off before was to prevent users from creating 10+ threaded holes/studs and then lagging the part studio until it is unusable. I realize now that kind of “hand-holding” really isn’t necessary and everyone is smart enough to figure out that this is a pretty heavy feature script to run if you have multiple starts or really fine pitch threads. The script is actually quite optimized but the predominant bottleneck for performance is the sweep and union functions which each can take hundreds of milliseconds to solve (When you add up ten 200 ms sweeps you're waiting for 2 seconds just for the part studio to load).
One last thing, in the picture you uploaded you selected a threaded M3 hole and I wanted to let you know that this script was not designed to interface with any standardized threads. If you want to, the hole/stud size needs to be the same diameter as the external thread of the corresponding bolt. So for an M3 screw to thread in, the hole would need to be 3 mm and the pitch 0.5 mm. External threads act like a die and cut into the cylinder while internal threads add material to match the external threads given the same diameter. This means that internal and external threads from the same diameter cylinders match and thread together.
With these changes, I updated the UI so it is easier to see how the more advanced features expand the functionality. I hope you can finally use this feature script how you initially desired. Let me know if you have any more issues so I can resolve them.
You can find the new version here (Plastic Thread) or you can just update the feature in your tool bar in any part studio.
Thanks for creating this - already used it a couple of times. I am getting an error that says I can't specify distance on internal thread - is this correct/
@bruce_norman979, that error will appear if you select an internal thread and check the thread length checkbox. It will also appear if you select an external thread and specify its length in the same selection as an internal thread. I might remove this error because it's not that useful, especially when you are making multiple selections. Still, it shouldn't get in the way because that error can't prevent the creation of the threads.
Hey All,
I've been working on this feature script recently and just finished up the V1.5 update. ACME threads are now available, and there are quite a few new features and fixes.
You can find the feature here: Plastic Thread
Features:
I've also made a quick overview video showing off the current features:
Feel free to post any recommendations or bugs here or in the comment section on the video. I tried to do a lot of testing to make sure the feature was very stable and that all the combinations of options worked, but there are always going to be outliers that I missed.
I also made a custom table as part of this feature script. If you add it to your custom tables, it will display a lot of background information about each thread. I made this to see the pitch and recommended layer thickness before the view menu, so it's not necessary unless you want a table with all the holes in one place.
Thanks to everyone who has already used this feature script. I hope old and new users get a lot of value out of it.
@william_knoblauch Beautiful work here! For the heck of it I just gave it a quick spin using the Basic settings and it Just Worked with my first test print! A sincere thank you for the effort you have been putting into this!
Yeah, this is great! P.S. If you ever revisit this another time, I feel like I could get by with fewer significant digits. But this isn't a big deal, and if you have bigger fish to fry (and who doesn't?) then forget I mentioned it.
@daniel_melameth Thank you! I'm glad it worked out of the box, that was the goal all along.
@kenn_sebesta167 You're very right and I did fix that in the latest version (1.5 patch 2) because I removed that message all together. Now you are given the option to view the pitch, TPI, and minimum layer thickness in the feature dialog. Just right click on the feature in the drop down, when you are in a part studio, and click update to get the latest release version.
The message system is quite limited and also limiting in terms of what you can do, so I switched it to an on edit driven parameter, which actually turned out to be way harder than I had anticipated, but it was fun figuring it out nonetheless. You can see the patch notes for that update in my comment just above. I also released a couple of patches to either fix issues or improve the user experience. One of which was making the Basic/Custom/Advanced tabs, as well as the thread profile and pitch/tpi input, remember your last choice so you can use the feature over and over without having to set up the threads again and again.
Thank you for using the feature even after having discovered the worst bug possible.
Hello! First off thanks for making this, super useful stuff. A possible feature request here, wondering if you might consider adding the functionality to split the bolt along its length, and then automatically create a square shaft that would be press fit into the head of the bolt. I am considering getting my feet wet with feature script to implement it, but its essentially a super minimal wrapper over what you already have. Below is how I've mocked it up, the head needs to be glued to withstand the pulling force when tightened, but the threads on the bolt print super fast in the flat orientation. Idk I'm new to 3d printing, not sure if this is even necessary, my thought is the threads will be stronger when the layer grain is normal to the thread.
Hi @conor_o_shaughnessy524, that's a good idea to make the threads stronger. Currently the featurescript doesn't make any new parts, it just modifies the existing parts in the part studio, so your suggestion wouldn't really fit with the design. If you made a stand alone featurescript like you mentioned, it could generate a bolt exactly like your picture given the diameter, pitch, and length. A parametric 3d print friendly bolt generator would definitely be useful, and it could be used in conjunction with female threads from plastic thread in order to bolt parts together (with stronger bolts) without any extra hardware.
I posted my question in the wrong location it can be found here.
Thanks
@doug_probst The underlying principle I used when making this script was that when selecting two cylinders, they will have the same threads without needing to account for the pitch on the female threads (a M6 x 1.0 screw will thread into a 6mm hole that is threaded to 1.0mm pitch using the plastic thread script). Because I made that assumption, you have to do a little more work if you want to define the threads by the inside diameter of the female threads.
To answer your question, you simply need the ID of the threaded section of the tube to be 47mm + 3.5mm (50.5mm) to make the ID of the threads slightly more than 47mm. Adding the pitch to the diameter of the hole should yield the desired result. However, because the tolerance is applied to both the male and female threads, neither part will be exactly the given size. Therefore, I would recommend checking the ID of the internal threads and adjusting the size accordingly. Additionally, the cylinder you select to create the male threads should have the exact same diameter as the female.
I think it would be useful, especially in your case, to add the functionality to choose whether the male or female threads determine the size of the thread. However, currently, you will have to perform some math to get the output you want.
Thank you so much for making this script and responding to my newbie question! I did just finish printing the final version of the female thread and removed the additional .5mm I had added to the diameter and with the custom thread pitch of 3 the fit is PERFECT! Just need to reprint the male side in TPU to absorb impact if the inner tubes are dropped in uncontrolled. This part is for the bottom end of an extendable 33ft fiberglass antenna.
Thanks again!
Doug
Hi @william_knoblauch,
I tried this feature script and works flawlessly on the first print.
Thanks a lot for this!
However, in my next model I am trying to add thread length on an internal thread, but I get an error.
I am relatively a beginner to Onshape (and CAD), and I want to know if its possible to add length to internal thread using Plastic Threads feature script?
If yes, could you please point out instructions to do so?
Thanks
@shameek_vats,
Your comment actually got me to add the partial internal thread functionality to this featurescript finally. My initial idea was that people wouldn't need a partial internal thread, but after several requests, I realized it's not about implementing what I think people want; it's about giving everyone options.
New version: Plastic Thread V1.6
So I've implemented partial internal threads and, in the process, cleaned up the partial threads functionality.
You can update the featurescript in the toolbar by right-clicking on it and clicking update.
If you encounter any bugs with the code, please let me know. You can also partially thread double-headed bolts. I don't know why you would really want to do that, but now you can.
Oh, and I made it a little more lenient when selecting a cylinder that isn't exactly equal to the theoretical cylinder size. It should now accept cylinders that are slightly smaller or larger when uneven chamfers cover the edges of the cylinder. You still can't add threads to a hole through a rod, mainly because the chamfer doesn't look good.
Hi! Thanks for this super cool project. I may be missing something obvious, but I couldn't seem to not have interference. In part studio I gen'd up my male & female parts, threaded them up, then over in the assembly rotated (see attached). EDIT: oh, for both threaded surfaces, I couldn't flip the direction independently—I think that's the root of my problem. Ya— I have a 28mm thread in a 30mm slot, creating a 2mm bolt head. However, that "head" is at the opposing end in the female threads! No worries—i'll just thread 'em indepedently.
@william_knoblauch
Hi, very cool this script, thank you
Is there a hope to have unit in mm, especially for pitch ?
Hi @cdaringe,
That's a kind of limitation with the code right now. You have to separate the thread creation to rotate them independently. I could add a feature to edit the properties of the threads independently, but it would be somewhat useless and confusing.
Hi @patrick_monnier,
You can enter any unit for pitch. When I'm threading for an M3 screw, I set the pitch to 0.5 mm, and it works perfectly. I think it defaults to inches because that's what I set the units to in the bounds of the text box, but it can take any unit you specify.
@william_knoblauch
Thank you that works if entry unit mm.
Another question: in the view section, what is this Pitch value 3.175mm
Where do you view layer information?
This Feature was a lifesaver for my most recent project! Thank you!
@patrick_monnier That shouldn't show up when you have specified a custom pitch/TPI for your thread. It won't do anything because it's just displaying the pitch it would use, given the diameter of the cylinder you selected. To my understanding, there can be some mismatches between that display and the current state because I'm using a viewEditLogic function to dynamically update that info, which can get out of sync with the current inputs easily.
The idea behind that view menu is to see that info in basic mode, where the pitch/TPI is automatically calculated based on the cylinder diameter. The layer thickness is useful in every mode because it shows what the "minimum" printer layer thickness is to achieve a good print. The only problem with the layer thickness is that it's a naive calculation that assumes that to get a good print, the smallest detail on the thread needs to be equal to the layer height. In practice, this is not true. I've printed some M3 threads with a 0.16 mm layer height and got around the thread-detail issue by up-sizing the hole. There's also a button to do that at the bottom of advanced mode called "Increase small hole tolerance", which should do that for you.
@brian_wagener If you're talking about the minimum layer thickness, you can see it in the view menu at the bottom of the regular inputs. You might have to scroll down depending on the size of the pop-up. That's the only layer thickness info in the feature; any other layer info would be in your slicer.
Thanks @isaac_friedlander849, I'm glad you found it useful!
Thank you @william_knoblauch for this feature.
I need to 3D-print a 3/4" BSP thread. It's close to ISO except angle is not 60° but 55°. An option override default angle would be great.
- do you planned to add this or is it something you won't take time to add ?
- would you be open to contributions ? I'm actually a dev and created some (simpler) extensions; I think I could manage to add an option
- in that case, would you create a Github repo to host and centralize code and make possible to people to suggest PRs ?
The question is: where to add this in the UI ?
- add a third tab "Custom" in addition to existing "ANSI/ISO" and "ACME/DIN" ? Or a "BSP" tab maybe ?
- add an option inside each existing tab for angle customization
What do you think of that ?
Thank you
Hi @william_knoblauch. Thanks a lot for the feature.
However, I have one problem with internal threads. I designed a container based on two circle and added a thread to the two parts. As I require a slot in the container, I noticed the threads create an extra wall, although I specified that the threads should have a length of 5 mm. Any way to avoid this (except for splitting the cylinder into two parts?
(deleted)
