Inserting multiple assembly positions into a drawing.
aubrey_cousin
aubrey_cousin Member Posts: 15 PRO
Is there a way to do this or can this be added?
  • aubrey_cousin
    Thank you all I'll just do what I thought I might have to do. Haha.
    @philip_thomas - Yes, I was looking for Alternate Position Views. Stacking the views with hidden lines or just placing the views side by side to show open and closed position dimensions. Either would work honestly however it seems we are waiting for this ability. Thanks.
  • aubrey_cousin
  • matthew_stacy
    matthew_stacy Member Posts: 489 PRO
    I successfully approached this task, of inserting multiple assembly positions into a drawing, by creating assembly configurations rather than branches
    However, what I would really like to do is overlay the two resulting drawing views to illustrate the range of motion of an assembly (similar to what is shown in the attached 5093A750 drawing from McMaster Carr).  Does anyone have suggestions as to how I might:
    1. align those two views (to perfectly overlap) and
    2. display the second view with dashed lines (or somehow represent it as a 'phantom')?
    Thanks.
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,100 PRO
    unfortunately, there is no good solution.
    What I have done in the past is have one shaded view and one not shaded view, then overlap them "eyeball"
    You could also export one position to dwg, then insert that into a part studio. Then insert sketch into the drawing. That way you can set the lines to a different color, or make them construction lines.
    Like I said, no GOOD way... but it should get you by for now.
  • nick_twillert
    nick_twillert Member Posts: 1 PRO
    Is there still no good way of doing this?
  • raj_Onshape
    raj_Onshape Onshape Employees Posts: 113 image
    You can use assembly Named positions now
  • john_mcclary
    @raj_Onshape That isn't true.
    What we are looking for is a way to show the machine in one position, and in the same view show the alternate position in phantom.
    Like SolidWorks Alternate Position View
