Why isn't it possible to pattern a spline?
terry_kuehne236
terry_kuehne236 Member Posts: 13 ✭✭
I'm trying to remove drawer edges and I'm wanting to do a linear pattern in the sketch. Would this process be better done at the feature level?
  • terry_kuehne236
    How do you pattern a feature when you can only pattern parts, it seems.
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,120 image
    In the pattern feature, select feature pattern instead of part.
  • NeilCooke
    Always.
  • terry_kuehne236
  • NeilCooke
  • onshaper
    onshaper Member, Mentor Posts: 99 ✭✭✭
    linear pattern in sketch doesn't seem to have a feature pattern option (or any options). and yet it cannot linear pattern a spline
  • CADNurd
    CADNurd Member Posts: 166 ✭✭
    I think that's also the case with SolidWorks, so it's probably a Parasolid Kernel limitation. Using '3D Fit Spline' you can convert your spline into a 'curve' and that then can be patterned.
  • ry_gb
    ry_gb Member, csevp, pcbaevp Posts: 272 PRO
    @CADNurd I would use Composite Curve instead to avoid any issues with approximations from 3D fit spline.
    Ramon Yip | glassboard.com
  • ry_gb
    edited June 12
    I'm sad to report that you can pattern style splines in SolidWorks (I checked in 2025). You can also pattern regular splines, but not parametrically.
    Edit: Sad because it means it's not a Parasolid kernel problem.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,923 PRO
    You can also pattern the sketch feature itself. Not the sketch pattern tool, the pattern feature (set to "feature") and picking the sketch containing the spline.
  • CADNurd
    Useful. Will try to remember that. Have you always known this workaround, or did you just discover it today? None of the LLMs seem to know about it.
  • martin_kopplow
    martin_kopplow Member Posts: 1,639 PRO
    It works, I've also used that to create brake discs in the past. Many times, creating a solid and then patterning that is the better approach, but there may be times where we don't want that.
    Don't forget this is a feature pattern. Else it won't let you select a sketch.
