New FeatureScript Weld
emagdalenaC2i
Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
We would like to introduce you a new FeatureScript that @mbartlett21 and I have created
FeatureScript Weld
This custom feature creates welds using the user’s selection.
It currently supports fillet welds and many types of butt welds.
Something I think Onshape people will like to know is that Morgan @mbartlett21 and I do not know each other. We have never seen each other in real life or online, we have not heard our voices and we are even literally in the antipodes of this precious connected planet, Australia and Spain.
Un saludo,
15
Onshape, Inc.
The collaboration aspect is wonderful as well -- the world gets smaller one feature at a time
@ilya_baran
@john_mcclary
Thanks!
But the code is new and we are not using code from nDraft. as you can see in this GitHub PR.
Fortunately, @urszula_wachulska has also participated in the project, as you can see in this issue of GitHub, although she has not participated in the code, which is why she does not appear in the copyright.
By the way, many thanks to @urszula_wachulskafor her advice and information.
This project is open to anyone who wants to collaborate, there is already an open issue with the points to add in version 2
@mbartlett21
@urszula_wachulska
Great Job! A wonderful collaborative effort.
Will FS weld create a V butt weld on two cylinders [two different parts]
The main changes I would need are (in order):
- addition of stitch welding (intermittent).
- partial weld distance (this could work similar to the recently released partial flange or partial fillet features)
- butt welding on an in-context part studio.
- the icing on the cake would be the ability to wrap welds around the ends of plate. I have gotten into some scenarios where the current feature script doesn't do so well near tube radii and the ends of plates.
Overall I am really impressed with this script! I can literally detail out the welds in 3D faster than I can mark up a 2D drawing. And the downstream efficiency of training is night and day compared to looking at 2D print!@MBartlett21 and I shared the code for this FeatureScript on Github https://github.com/mbartlett21/weld-featurescript and for version 2 some of these options were indicated. See https://github.com/mbartlett21/weld-featurescript/issues/53
Actually you can use this FeatureScript in an in-context part studio
Here I modeled something sort of crude for what I am envisioning with a butt weld. And then getting the fillet weld to join nicely with the butt weld? THAT would be amazing.
This is one neat FS with a lot of potential!
I have two questions:
1. Is there an option to make offset in respect to center of material thickness, of for example "V-Butt weld"?
2. Is there an option to combine for examples "V-Butt weld" and "Bevel Butt"? One on one side of the plate, and one on the another.
Would it be something similar to this? You can set the Root gap manually
I think so. Try Other side option
You can also play with the Root gap in both sides
I've got only a question:
Is there an option to make offset in respect to center of material thickness?
This is greatly needed for thicker materials joint design, as they are not symmetrical through thickness most of the time.
i created a frame profile that i was going to use
https://cad.onshape.com/documents/4fcf33de1f152e785f31347e/w/f8702f3742da8dc95c06b42b/e/225463a52b1d6042fd1acc23?configuration=List_oltaa6HRMR90ya=Default&renderMode=0&uiState=640e0c3ebd12d07f312b05ad
ill need to look into how to use yours
thanks
Just came across this custom feature. It looks really useful, but I can't seem to manage to weld coped profiles with it. Is this possible?
I don`t think so, I-ve had a cimilar issue, it seams not to work well with cilindrical faces.
I love this feature! It`s really well done.
The only think I`s add is the possibility of using a cilindrical face. For exemplo if I want to weld a planar face into a filleted face, like in the picture attached.
