Is there a way to have cutouts on a Sheet Metal part be a recess instead of a through hole?
This is a strange application but for a project I'm looking at getting sheet metal cut on a router to be bent, but it has shallow recesses for plates to be located and welded on afterwards. I have played around with the finish sheet metal model tool, however these changes don't propagate to the drawing as they were after the "finish". As I need to give these to a machinist what would be the best way to go about this? Is there a way to incorporate these changes or is it easiest to do some clever modifications in a drawing? Any feedback or advice would be greatly appreciated
