Chamfer callout missing?
gerry_patterson
Member Posts: 1 ✭
Hello,
I've been trying to locate the chamfer callout dimensioning tool. Typically, one sees something like .03 x 45° with a leader. While I could create a note, I was hoping for an associative method, so if I changed the model, the drawing would also update.
Thank-you,
- Gerry
Thank-you,
- Gerry
It's not in yet. Put in request with the "?". I am sure it will come in soon, as it is a std requirement.
Only work around to enable association is to use 2 dim's.
Linking dims into notes would also be handy, if this was in you could link the 2 dims into a note but alas it is not available either.0
