Chamfer callout missing?
Hello,
I've been trying to locate the chamfer callout dimensioning tool.  Typically, one sees something like .03 x 45° with a leader.  While I could create a note, I was hoping for an associative method, so if I changed the model, the drawing would also update.
Thank-you,
- Gerry
  • brucebartlett
    edited December 2015
    It's not in yet. Put in request with the "?".  I am sure it will come in soon, as it is a std requirement.
    Only work around to enable association is to use 2 dim's.
    Linking dims into notes would also be handy, if this was in you could link the 2 dims into a note but alas it is not available either.
