Follow Mode does not work
scott_karlins689
Member Posts: 2 EDU
Follow Mode does not work when there are four or more users in the document. All the additional users beyond 4 shows up as a +3 or whatever the remaining total is. You cannot click on that Social Cue. You can hover over it, and it will give names, but you cannot click on the name to start the follow.
Is there any other way to do the Follow Mode?
Thanks!
Thanks!
Please use the Contact Support item in the help menu to open a ticket and we'll take a look. A screenshot of the issue if you can easily reproduce this with some other people would be helpful too.Director of API, Appstore, and App Partner Technical Support0
Was this ever resolved or is there a work around we are hitting the same issue.0
This is a limitation in the UI for Follow Mode when there are many users in the same doc at the same time. Please submit a bug.Senior Director, Technical Services, EMEA0
any progress on this?
The only value I've found for follow mode is to see what/where a colleague is working. Beyond that, if I really want to see the process, I use screen sharing with a video call (e.g. Zoom). It's much better. Much of the important interactions are lost in follow mode.
we've got about 10 of us on the robot at once, and the mentors want to jump around to see what each student is doing.
