Fill Surface
jd_welch
Member Posts: 1 ✭
I've created a skeleton for a surface to fill in but I cannot figure out how to fill in between the lines. I'm used to the "Fill" feature in Solidworks and that may be my issue.
Note: I didn't finish the sketch on the opposite side because I couldn't figure out how to fill it in.
Can you make your model public, then paste the URL from the browser address bar in a message on this thread?
There is no surface fill yet in Onshape, but if I understand you correctly, you should be able to achieve the result you want using one or more surface lofts.
