Improvements to Onshape - January 7th, 2015
lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
edited January 2015 in New in Onshape
We recently updated Onshape with a few new improvements and are anxious to hear your feedback.  Improvements include updates to some existing functionality like sketch mirroring and assembly mating, as well as a few new features like polygon and thicken!
Highlights Include:
  1. New polygon tool in sketching (both inscribed/circumscribed)
  2. New thicken feature converts surfaces, closed profile sketches and existing faces into solids (integrated boolean like Extrude).
  3. Sketch mirror now maintains the construction state of mirrored entities.
  4. PDF tabs will now retain the scroll position in the preview. (when you leave and return to the tab)
  5. Improved assembly alignment (Mate alignment will first show the closest solution)
We are already hard at work on additional improvements and look forward to hearing your thoughts on this release.  Our team is also working on perfecting the entire update process to be as seamless as possible so please let us know if you experience any disruptions or anomalies in your service.  Leave your impressions in the comments!
