Yet another Mass Q involing Learning Center/ . . . /Sketching In-Context
So I posted in this thread :
https://forum.onshape.com/discussion/2314/no-mass-properties-icon#latest
But decided to make a new thread cause that one was marked "Answered".
So I'm at the end of 'Sketching In-Context' and they ask for the Mass of 'the part'. I did the exercise and got the wrong answer. I only have 1 part to check Mass on. Now on page 6/8 in this lesson it says "Create a new part by extruding the correct sketch faces." I extruded but it never made a "Part 2". What am I missing? Going to go through it again and see what I could be missing.
jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 665
Pay close attention to the image on 6/8. The boolean type is 'New' which will create a second part. By default, if the extrude is touching a face we will select it to be 'Add' unless manually changed. Edit your extrude and change the type of 'New' to get a second part.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
noa Onshape Employees, Developers Posts: 141
Hi @david_cushing, after creating two parts instead of one you should get 50865.396 mm^3. There was a slightly different number labelled as the correct answer but it has been fixed and changed to this now.
Noa Flaherty / Customer Success / Onshape Inc.5
I still didn't get it right since my mass was off, but I did get it to be 2 parts in the end.
I will return and try this again to see if I can get it right, 2 parts and the correct mass.
