Can't chamfer an edge
henry_feldman
henry_feldman Member Posts: 136 EDU
So this may be stupidity (or OnShape noobness) on my part, but I can't chamfer an edge in the image below; all the other edges took a chamfer or fillet as needed. There is no error that I can see, and sometimes it shows a preview briefly of a chamfer or fillet (I tried both) but it goes away shortly after appearing. I don't know if this is due to a constraint (that bar going towards the bottom is constrained to coincident to the right edge of the object). I have made the document public and it is called "Sternal Retractor - debug".
  • lougallo
    lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,020 image
    @henry_feldman My guess is the edge is smaller than the fillet will allow.  Does the dialog where you enter the size have a red border?
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
  • henry_feldman
    There is no red border, and at least on the iPad there is a failure error message (no reason, just that it failed). The object is 25mm wide and I was trying a 1mm filet.
  • henry_feldman
    Btw: I wasn't originally using the iPad, but figured I would try it in case it was a browser issue.
  • henry_feldman
    viru said:
    @henry_feldman , You can give either 5 mm fillet or 1 mm chamfer in your model. I found below observation in your model.
    1) If you want to keep chamfer = 1 mm then you can give fillet value maximum upto 4.6 mm in your model.
    2) If you want to keep fillet = 5 mm then you can give chamfer value maximum upto 0.93 mm in your model.
    3) If you want to achieve your requirement fillet = 5 mm and chamfer = 1 mm then you have to apply chamfer before than fillet on your model as shown in below video.
    Kindly refer below video for more detail.
    Wow, that was perfect. Thanks for spotting that. It would be an awesome feature if it highlighted where the fillet/chamfer failed, so you'd know what to do (without your experience). Thanks for making the video, that was incredibly instructive.
