3rd Party app support (Clara)
michael_lesliemichael_leslie Member, Mentor Posts: 21 ✭✭
Hi,
I'm in the appstore beta anyone know where to get help regarding one of these apps specifically Clara Rendering.
I want to rotate the model relative to the environment I might be being a bit stupid but I can't work out how to do it.
Thanks
Michael
  • michał_1michał_1 Member, Developers Posts: 215 ✭✭✭
    What you see by default in Clara.io app is just they visualizer, it's a simplified editor, very simplified. Right on sight you have a propeties panel, go to share section. Here you have two large buttons VIEW IN CLARA.IO and EDIT IN CLARA.IO, use edit. That will open your file in proper editor. It's rich in function so you will need to read they User Guide (in Clara.io editor in right corner you have Learn button, use it or here you have direct link : https://clara.io/learn/user-guide ).
