Lock files in your project list
henry_feldmanhenry_feldman Member Posts: 131 EDU
Can we add a feature to lock files in the list? It is so easy with the click to select model (unlike OS norms) to select multiple projects and move to the trash. Several times I have moved a critical project to the trash, luckily realizing that I did it and returned it to the list. The other choice would be to not allow multiselect on trashing.
    @henry_feldman , Currently this facility is not available in Onshape. You can raise improvement request for this.
  • henry_feldmanhenry_feldman Member Posts: 131 EDU
    I did. just figured I'd voice it to the users too...
