Nesting Parameters-- "precondition analysis failed"?
dave_cowden
Member, Developers Posts: 484 ✭✭✭
I'm trying to use a feature to conditionally define other features. I see this done in many of the std features, but I get an error "precondition analysis failed" when using the pattern myself.
Why does this code produce "precondition analysis failed"?
export enum AnsiOringType{
annotation { "Name" : "AS568-001" }
AS568_001,
annotation { "Name" : "AS568-002" }
AS568_002,
annotation { "Name" : "AS568-003" }
AS568_003
//and 932 more
export enum LocationOffsetType{
annotation{ "Name" : "Offset From Plane" }
PLANE_OFFSET,
annotation{ "Name" : "On Plane" }
PLANE
//annotation{ "Name" : "Vertex" }
//VERTEX
export const oRing = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "ANSI TYPE" }
definition.ansiType is AnsiOringType;
annotation { "Name" : "CylindricalFace", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
definition.referenceFace is Query;
annotation { "Name" : "LocationType" }
definition.locationType is LocationOffsetType;
annotation { "Name" : "ReferencePlane" }
definition.refPlane is Query;
//the conditional definition here is what causes the error.
//builtin features do this., but here it doesn't work?
if ( definition.locationType == LocationOffsetType.PLANE_OFFSET ){
annotation { "Name" : "OffSet" }
isLength(definition.offset, LENGTH_BOUNDS);
...0
dave_cowden
Duh, I figured it out. this annotation:annotation { "Name" : "ReferencePlane" } was missing the filter clause.5
