Reverting from Circle to Polygon
gabriel_stein118gabriel_stein118 Member Posts: 6 EDU
Hey, I have been working on Onshape for a few weeks now, but the past couple of days I have struggled to resolve an issue. My document contains many circular forms, all of which are based on sketches with circles. Despite the fact that the forms were original sketched as circles (and when I double-click on the sketch, it is shown as a circle), the final form displays the circles as more crude polygons, mimicking but just approximating the shape of the circle. Does anybody know why this may be the case? I can't seem to find a fix.
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 image
    This is purely a graphical thing, the objects you created are still circular.  The tessellation of your models has an angular tolerance and approximates the circular edges with segments of lines.  The tighter the tolerance, the more circular it looks.
    Right now we don't have a way of changing the tessellation.
    Jake Ramsley
  • gabriel_stein118gabriel_stein118 Member Posts: 6 EDU
    Thank you very much, jakeramsley. While I am sure that it is a graphical issue, sometimes it displays the circles as circles, and other times as polygons, no matter what the zoom or configuration. It seems like Onshape is perfectly capable of rendering those circles as circles, and sometimes it just errs. Do you know if there is a way that I might be able to more predictably have the circles displayed as circles? While it may very well be a graphics problem, I wonder if there is a way to the get desired rendering that I now only occasionally happen upon. Thanks!
    edited January 2016
    @jakeramsleyWithout a way to change tessellation it becomes very hard to analyze interference of an assembly at times. Is this way of changing tessellation in the works?
    I just realized this was in the Drawings category.  If you click on the 'Refine graphics' button on the far right it should turn coarsely rendered circles into finely rendered circles.
    In part studios and assemblies, the coarseness of the tessellation is related to the number of faces rendered.
    Graphical improvements are currently being worked on including the rendering rendering of circular faces/edges/etc.
    Jake Ramsley
    jakeramsley thanks again. This is very helpful. However, just to be clear, this refining feature is only possible in drawings, right? It isn't possible in the middle of modeling? Thanks.
