What does making a document public actually mean?
nyholku
Member Posts: 60 PRO
I just first time experimented with making a document public.
When I did this, it was just a click and then the documents was listed as 'any user can view and copy'.
Now, am I the only one who sees this as a little bit too simple and loaded with potential issues?
No rules about what everyone can do with the public models, no warning about possible legal issues?
And and also a bit misleading, eh? Sure any one *can* now copy the document but are they legally allowed to do so?
Publishing a song, a book, a software or a webpage does not allow anyone to copy it because of the copyright.
I'm pretty sure the same applies for published OnShape documents, they are copyrighted and thus copying them may infringe the authors rights.
If making a document 'public' waves those rights by some OnShape user agreement then this should be clearly stated at the publishing stage.
Incidentally I'm not aware of any terms in the end user agreement (not sure I've seen EUA at all, let alone read it if I have seen it).
Besides there are some rights that cannot be waved such as the right to be recognised as the author or protecting the integrity of the copyrighted work, what ever it would mean in this context.
Some food for thought.
br Kusti
br Kusti
don_howe
Member Posts: 136 ✭✭✭
There is another way to reduce the file size of your document without having to make it public, provided of course you are not to concerned with the history of your document. I believe if you make a copy of your document and save it under a new name it clears all the history. The reason the file is so huge is OS records everything thing you do. The ability to purge the document history would be a nice feature.kustaa_2 said:don_howe
Thanks for the comments.
Making a document (temporarily) public seems to be the only way to reduce its size if you are over the free plan limits, hence the question and how I stumbled to this issue.
The other thing I see is that some people are trying to exploit the free plan which is really offered I think to allow people to use OS and explore its capabilities with the intent that if the individual is satisfied they'll sign up for the subscription plan ($100/mo). That's a little rich for my hobby budget but if someone is using OS for their business or professional work under the free plan and then are a little miffed at the public domain criterion of OS then maybe they should step up to the plate and sign up for the subscription plan. I'm not trying to upset anyone here, I just don't want to see the free plan get jinked because it's being abused. (IMHO)
6
Chances are unless you call direct attention to your document (aka you need help with something) it will likely go unnoticed in the public domain unless someone is actually looking for a part/assembly similar to what you are doing.
If you have document and you're concerned about legalities, intellectual copy rights and so on, then don't make it public. (IMHO)
Best,
Dan Shore
Best,
Dan
Also making documents public is the only way you can utilise the free plan to the advertised 5 GB.
True it is unlikely that anyone finds a document that is only briefly public. At least not by accident.
However it is not beyond realm that someone makes a 'robot' application to routinely scan for newly made public documents and automatically create copies of them as soon as they appear. In fact in the long run this is almost guaranteed to happen, heck Facebook, Youtube and Google base their living on this sort of thing, spying on your every move and helping people to infringe on other people's work.
Not a big concern for me personally, but a relevant question I think.
Especially since OnShape UI does not in anyway convey that there might be some reservations or restrictions to the usage of public documents, on the contrary it says 'anyone can view and copy'. The real stuff seems to be buried in "Section 11(A) of Onshape's Terms of Service", a document most people are unlikely to read let alone understand deeply.
Just to be on the safe side in the future whenever I make something public I will include a tab/pdf reserving all rights and prohibiting copying to the extent allowed by the law (I'm a Finnish citizen and the Finnish law does not allow restricting copying for personal use ... you can take that as taste sample of how tangled web the copyright law is).
with best regards Kusti
While the suggestion of attaching a file with license to it is ok as a temporary patch, the provenance of a given part could be lost. This is less of an issue for me, since I am in education funded by government grants, so much of my stuff goes into the public domain (or at least needs to have parts of it publicly shared)
