Exporting sketch as DXF - Scaling
I am wanting to get a part laser cut.
I set my units to mm, dimensioned a major length to 76mm, and exported a sketch as a DXF for laser cutting but the company receiving the file found the scale to be incorrect with the 76mm length being ~3mm.
How can I ensure I'm exporting the same scale as what is showing in the drawing?
Can you clarify where you are exporting the DXF from? I see you say you are exporting a sketch, but then later on you talking about the scale on the Drawing.
Jake - To export the DXF I am right clicking the sketch in the features window then selecting "Export as DXF/DG". Apologies, when I stated 'Drawing" I meant "Sketch".
1) Upload the .DXF back into your document
2) Start a sketch and choose 'Insert DXF or DWG'
3) In the insert dialog, choose the units 'mm' at the bottom and then select the DXF that you uploaded.
This leads me to believe an export of a sketch to DXF takes the units as inches, regardless of the default units.
Surely it would be possible to export a DXF with 'mm' units with a minor software change?
1. I set my units to be millimeters and made a sketch with a circle and a spline in it. I right clicked on the sketch and chose to export as DXF.
2. I re-uploaded the .DXF and started a new sketch. I chose insert DXF and selected my file with the unit type being 'Millimeters'. The result is that the sketch made from the DXF is the same size as my previous one.
If you are willing, can you send a ticket via feedback and share with support?
I am unsure how this error occurred initially though, as my default units have always been set to 'mm'.
If you are interested in investigating, the change of units is stored in the history of the workspace you are in.
I am trying to export 2d profiles of a model, there is not option to do this from the Part Studio. So I created a drawing using one of my A3 (blank) Templates, but, this scales everything down to fit the size of the A3 sheet.
As work around I open the sheet and set scale it 1 : 1, which then will exceed the paper size, but it shows the profile 1:1. If you then right-click the sheet tab, you can actually export the profile at real size.
Currently I am not sure how to do it in a more obvious way as can be done in SW. It would be nice to see the export of DXF/DWG at 1:1 improved in Onshape - Gerard
