leader arrow sizes
colin_dalycolin_daly OS Professional Posts: 37 ✭✭
Any way to change the default leader arrow sizes in dimension and notes, or is it fixed to each drawing template?
  • shanshanshanshan Member Posts: 147 ✭✭✭
    now we could not change the sizes of the default leader arrow, but Onshape has added this requirement  into its improvement list, we will see it soon !
  • jon_mcintyrejon_mcintyre Onshape Employees Posts: 56
    Indeed, right now there is no way to modify it after a drawing is created.  The only way to control it at this time is to edit your templates in a DWG editor, then import and use those templates when you create the drawing.
  • colin_dalycolin_daly OS Professional Posts: 37 ✭✭
    Thank you guys for your responses.
    @jon_mcintyre where can we find instructions for editing such parameters in the template's
    thanks
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 558
    @_Dave_ Just to be really clear on your follow up question, @jon_mcintyre was writing the current work-around is to get the settings the way you want in your .dwt template using your DWG editor.  And by DWG editor you can infer AutoCAD ($$$), DraftSight, ARES Commander (last two are from Graebert) - as some examples.  For you that means looking into your DWG editor's help documentation to set those items before you export as a .dwt file and import into Onshape.
    @pete_yodis  Thanks, for the reply. I'll look into my editors (draftsight) help documentation.
    _Dave_
