RE: Is there anything preventing you from using Onshape?
It's been about a week since I started using Onshape, so you wanted me to check in with you.
You noticed that I haven't spent much time modeling yet in Onshape. There is something preventing me from using Onshape. I have checked out your resources page.
I have no technical questions about using Onshape, because I find Onshape unusable thus far and I have discovered your app & resources do not include mobile ability as described. As well, I find the other tutorials uninteresting and long-winded. Neither do I have the time to explore the tutorials further as it would require me to add yet another display to my existing render farm.
For what it's worth, I will use Onscape after it is more fully documented and fluid.
Thank you for your time.
-7
