Sweep with Twist
 thomas_kozak
                    Member Posts: 38 ✭✭
thomas_kozak
                    Member Posts: 38 ✭✭
                    I'm trying to follow a set of instructions for generating a hyperbolic worm gear.  One of the steps involves sweeping a gear profile along a semicircle while also twisting it by x degrees.  Possible in OnShape?  I don't see it on the Sweep tool and trying to fake it with Lofts seems to be imprecise.
             Fields
                            Member Posts: 7 EDU
                    I believe this is what you're looking for. Loft does work, but like using multiple points for a spline on a gear tooth, you need multiple sketches for the loft to follow properly. Also, getting the end conditions right is a pain. It's much easier to loft well past what you need, then cut out all but the middle section. Fields
                            Member Posts: 7 EDU
 Unfortunately this turns into a big file very quickly, and I had to save off a few times to keep my limit down.
 Here's the public file. Just use the rollback bar to follow the idea.
 https://cad.onshape.com/documents/56c4e376e4b098490f907d4b/w/208572b740acc9be5daf3838/e/19d350cf90fd4623bf0e8e67
 The cutting tool and end result. (I just copied another gear face and rotated a few times for effect)
 I don't trust a CAD system until I've broken it... repeatedly.5
https://cad.onshape.com/documents/6c5c1d79ed9d4cf9b75fd503/w/84bebcd7159144acbfe4fb8f/e/6a89e4751e7b4324a54d0125
https://cad.onshape.com/documents/49fb27a7c1ea4799bb684a99/w/3ab432355087408aacfa96b9/e/2670f4f809f84c55aa5f4202
