Is there a polygon function?
dave_cowdendave_cowden Member, Developers Posts: 483 ✭✭✭
Searching around, I cannot find a function anywhere that does it. looks like it should be in sketch.fs, but its not there.
I found this:
function createJogPolygon(points is array, boundingBox is Box3d, sketchPlane is Plane) returns array
but it  doesn't do what i want.
Unfortunately viewing the output of a polygon in part studio, it appears the tool directly generates the line segments and constraints directly, rather than generating a feature call that can be re-used...
  • dave_cowdendave_cowden Member, Developers Posts: 483 ✭✭✭
    Yes it is easy , but it seems like a function many will have to write over and over....
    sweet! that's a good addition.
