How do i create a new unit of measure?
dave_cowdendave_cowden Member, Developers Posts: 480 ✭✭✭
I would like to create a new unit that represents a threadpitch: threads per unit length.
Question 1: How do i do that?
Question 2: If i support threads/inch and threads/meter, how do i ensure these are converted property?
Question 3: how do i link my unit of measure so that when the document defaults are inches, my new threads/inch measure is the default, while if the document units are mm, threads/mm are the default?
Question 4: ( somewhat tangential): having values with units are cool, but why are the units always converted to meter before they are passed into the body of a feature. Is there some reason for this? it would be nice in some cases to know what the unit of measure the user initially supplied ( because for example you could accept dimensionless values connected with another length dimension )
Question 5: ( also somewhat tangential): how do you properly convert units? seems like the conversion is always done for me -- but always from what the user supplied to meter. I can't see where that code is, and/or how to do other types of conversations myself.
  • dave_cowdendave_cowden Member, Developers Posts: 480 ✭✭✭
    Ok thanks. The main reason I was needing to ask "was the cylinder length defined in inches" was because its the best workaround for the missing ability to define the UOM that i want. In short, in this case, using the dimension the user already supplied is a way i can interpret the dimensionless threads per input, without resorting to making them type the whole unit, or without hard-coding the unit of measure, which are both inadequate.
    Just consider this a "+1" for ability to add a proper, custom UOM.  Basically, both of the solutions you suggest in #2 are not nice for the user.
  • darren_13darren_13 Member, Developers Posts: 120 PRO
    On the back of this, I really wanted to create a unit for time. This was so that I could calculate twist based upon rotational and directional velocity, without the restriction of working in just a set unit (i.e. interchangeable between seconds, minutes etc...) Without this, I have to ensure the input is in m/s and rad/s only (excluding common definitions in RPM and knots etc).
    Cheers, Darren.
    actually in documentation we have:
    Values can be multiplied and divided. The preceding values are 1 * kilogram90 * degree, and 9.81 * meter / second / second.
    Is 'second' built in? auto complete doesn't find it?
    Cheers,
    Darren
    added these lines in my script:
    /** A constant equal to 1 second. */
    annotation { "Name" : "Second", "Abbreviation" : "s" }
    export const second = { "value" : 1, "unit" : TIME_UNITS } as ValueWithUnits;
    seems to be fine, can we get this in the units.fs?
    Cheers,
    Darren
